- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi
I have spent the last 2 days trying to draw a polyline but cant get it to snap to the correct location, the line keeps snapping to what I call phantom snap points in my drawing.
I have tried turning on/of various snaps in osnap along with the 3d snap, turned on/of "Magnet" in settings and resized the snap aperture box and selected various viewpoints.
I have reset Autocad to default settings on several occasions, copied my drawing into a new one with the same result.
Un fortunately this is not the only instance that I have had this problem.
I am using Autocad 2018 Educational Version on a Windows 10 machine.
Any and all help will greatly appreciated.
The fossil
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
would you please attache here your 3d blue line , for testing ?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If there are any phontom objects in the drawing you can get rid of them by running AUDIT
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Imad
Thanks for getting back to me.
I have attached the drawing, with the red circles, top one is the point I want to snap to and the other is the where the line actually snaps to.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The polyline's elevation value (origin and end point) is set to -3646.95, while the circle's centerpoint where you're trying to snap to have a Position Z value of -3748.98.
Since there are different non-coplanar Z-Values, you need to draw a 3D Polyline instead.
Try the attached file where I drew a magenta 3D Polyline on top of the original red Polyline.
Furthermore, after clicking a polyline vertex, you can press SHIFT + RIGHT-CLICK to show a menu where you can temporary enable/disable snaps:
Lastly, you're not working on the default WORLD UCS. To restore it, try typing UCS and then W.
Sometimes the Dynamic UCS get things messy. Press the F6 key to enable/disable it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for your CAD dwg . i open it and try snapping here and there and nothing weird found !! for that i suggest to select just one osnap mode for use no more , any changes ?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for that, I can now draw my line where I want.
The new problem, When I extrude the 3D poly line It doesn't extrude as a solid but as a mesh.
Same thing in other parts of the drawing where I have 2 entities on different planes, one a poly line, the other a 3D poly line. When I loft these two together they are not solid but hollow.
Cheers
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
check MOde option in Extrude command .
Command: EXTRUDE
Current wire frame density: ISOLINES=4, Closed profiles creation mode = Solid
Select objects to extrude or [MOde]:
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If you need to use a 3D Polyline instead of a 2D one because the points are not in the same plane, then presumably you will get a result that itself does not lie in a plane. If that's the case, you cannot Extrude it into a Solid, regardless of the MOde option you choose in the Extrude command. A 3D Polyline must be flat to be able to Extrude into a Solid.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
As @Kent1Cooper stands, all of the 3D Polyline vertices must be in the same plane (coplanar). You can check it by converting that 3D Polyline into a Region. If you get "0 Regions created" as result, the vertices are non-coplanar or the loop is not closed.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@fatal.error wrote:
... all of the 3D Polyline vertices must be in the same plane (coplanar). You can check it by converting that 3D Polyline into a Region. ....
Another way to check:
(vlax-curve-isPlanar (car (entsel)))
and pick on the 3D Polyline [or anything else that qualifies under the (vlax-curve...) functions]. It returns T if the object is planar, nil if not.
