08-07-2020
10:12 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-07-2020
10:12 AM
I don't see any easier method other than using properties to modify the length of all the Dynamic blocks at once. Select a dynamic block=>right click=>select similar=>open properties(ctrl+1)=> modify the length. One problem which you might face when you select similar a dynamic block is that it would select all the dynamic block with the same block name and will not select it based on the visibility states or different lengths. If that is what you are looking for to select the Dynamic blocks based on the length and then change its length at once then you can use the lisp attached. If that's not the case then you can post the drawing with a dynamic block and let us know what you trying to do. We will be happy to help you out![]()
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
