08-07-2020
06:47 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-07-2020
06:47 AM
You can take the copy from paint method a step further, and create a block containing the image. Example attached. Not a "bind" but essentially does the same thing. As long as you don't delete and purge the block from the dwg file, it is there...(at least it has been for me) a really large image will result in a really large file, but if that isn't an issue for you.....see attached example dwg (I don't remember where I found this trick on the internet, but someone else thought it up, not me)
