en respuesta a: Anonymous
I really like using the Viewbase command but it does have some limitations as you have seen.
One workaround that I've used is after creating the layout with Viewbase is I use the EXPORTLAYOUT command which creates a new drawing of the layout contents. In the new drawing I'm able to change the individual object properties as needed - each view comes in as a block and needs exploding. The downside to doing this is losing the dynamic view linking to the model.
