531 Vistas, 4 Respuestas
ctb error file pdf
Hi, everybody. I need a lot of help!
i have a problem with pdf printing with your ctb: color printing ignoring the ctb. also it's a problem i only have on my pc, from other pc i print in pdf correctly. what should i do?
the error message tells me that the print file is missing, but, I repeat, on other PCs it prints correctly.
Plotted with Warning(s)
File: E:\Lavoro\STUDIO LOCASCIOALBANO\RC255 - Marina Colonna\R.C.255_intervento spostamento vano\Riviera di Chiaia civ.255, piano quinto.dwg
Category name:
Page setup:
Device name: DWG To PDF.pc3 - plotted to file
Plot file path: C:\Users\marzi\OneDrive\Desktop\Riviera di Chiaia civ.255, piano quinto-Model.pdf
Paper size: ISO full bleed A0 (841.00 x 1189.00 MM)
WARNING: Incompatible or missing plot style
Etiquetas (1)
imadHabash
en respuesta a: Anonymous
would you show us your plot dialog with your full settings ?
Imad Habash
vinodkl
Try turning off background plot by typing in the command "BACKGROUNDPLOT" and setting it to "0". Now try to plot it to PDF.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
rkmcswain
It sounds like your PC does not have access to the plot style (.ctb file), and the other PC does.
In the PAGESETUP dialog box, upper right corner, where you specify the plot style, does it look like (A) or (B) below?
pendean
