- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
To feed another software I need to convert dwg to pcx. During plot after conversion some lines of a drawing missed which conversion to pdf kepp all parts. So it seems it is just cause of converting to pcx. And in preview all part are there in place.
Is there any solution out there ?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
can we know your plotter name and how you create it ? also we need your CAD dwg file please ?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
From the menu select Tools -> Wizards -> Add Plotter…
Select My Computer and Next
Select Raster File Formats and Zsoft PC Paintbrush PCX… continue with Next.
Continue with Next.
Select Plot To File, continue with Next
Define a name for the plotter AutroMaster.pc3 and continue with Next.Select “Finish”
When the drawing is ready to be converted select from the menu. Files -> Plot
To change the size of the plotted drawing select Properties
Verify that 256 (8 bits color) are defined under Vector Graphics.
Resolutions earlier defined are shown under Custom Paper Sizes. Select on of these or use Add to define a new resolution. I set it W:1680 H:1050
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
check my below attachments ( 60-SG21-00-J01q-0002-Layout1.pcx ) file and see if it's ok ?
waiting your feedback !!
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It seems perfect. the capture was just to show what is the issue. I normally should make a window over yellow rectangle (attached) and paper size 1680x1050. May I know how did you fix it? There are several pages I should go through.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I've just create the plotter and prepare my settings for plotting . see below image
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
higher rsolution, less lines miss. Please do the plot to pcx over the whole yellow rectangle in paper size like W:1680 H:1050.
I attached the plotter file.
What would be the problem then?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
it is the same as mine, some part of green drawings (J-Equipment layer) still missed.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
the software that I should use pcx for has problem with online conversion, I tried it before ![]()
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
in general ... AutoCAD is not the proper software for create images !! you have to expect pixilation and more !!
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I accept to loose the resolution quality but at my case it is selective and nothing happened on umbers and just on one specific layer (J-Equipment) some lines are removed. I admit that resolution can be degraded but being removed is odd.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I exploded all those green blocks and match the lines with a rectangle I drew. and now all lines are shown in PCX. Seems the block setting has problem which I can not find. and just exploding the block didn't solve the issue until I match the properties with the one I drew. Any suggestion to fix the block? then all drawings using the same blocks will be fixed.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
