759 Vistas, 6 Respuestas
MASSPROP command vs Parallel Axis Theorem
I've been trying to calculate the Moment of Inertia of this compound section:
Here below some data that I have used for my calculations. The centre-to-centre distance between the 2 trapezoids is 25 mm:
As you can see, Ixg calculated with the equation and Ixg calculated with the MASSPROP command of AutoCAD aren't the same. Both trapezoids have been drawn with polylines and I used the REGION command before using the MASSPROP command to give them a solid feature.
Can anyone please shed some light on this?
Thank you
Etiquetas (1)
