310 Vistas, 3 Respuestas
What is the name of my custom toolbar?
I am currently using AutoCad 2014 sp1, in classic mode with custom toolbars. It was quite a task creating the tool bars
when I upgraded to 2014. We have signed up to upgrade to 2016.
Will the upgrade recognize my current classic setup and keep it, or will I need to start over again?
beyoungjr
en respuesta a: Anonymous
AutoCAD classic is gone in 2016:(
Toolbars can still be imported from an old CUI so your work custom toolbars need to be in a saved CUI from 2014 to use on a clean 2016. Clean would be the best way to go but 2014 and 2016 can exist on the same PC if necessary.
Blaine Young
Senior Engineering Technician, US Army
en respuesta a: beyoungjr
Thank you. Just to clarify. If I install a clean and separate version of 2016, I can continue to use my current 2014 until I am satisfied that the CUI transfer is working correctly in 2016. Victor E.Kollasch Project Manager Balmer Architectural Group, Inc. 2425 E. Camelback Rd., Suite 775 Phoenix, Az. 85016 ph: 602-954-6718 fx: 602-468-9680 vkollasch@bag-inc.com
rkmcswain
vkollasch wrote:
Thank you. Just to clarify. If I install a clean and separate version of 2016, I can continue to use my current 2014 .....
Yes, they will run concurrently from a technical standpoint.
From a licensing standpoint, consult your EULA and the T&C of your subscription agreement (if any).
As far as the toolbars. I would suggest creating a new empty "vkollasch.cuix" file and keep this in a folder like "C:\CADSTUFF".
Put your toolbars, ribbon, pull-down, whenever, in this CUIX file.
Then simply load this menu as a partial menu in 2014, 2016, 2017, etc, etc...
No migration, no headaches, done. It will help you today and tomorrrow.
