388 Vistas, 1 Respuesta
Data Extraction - Ordering object from origin
Hello All,
I'm new to AutoCAD.
As part of a bigger task, I'm extracting the objects (and blocks) from a DWG file using the Data Extraction feature available in AutoCAD. Since all of them have a reference positions X and Y, I'd like the output to be ordered/sorted with respect to the origin - left to right. Is there a way I can achieve this ?
TIA.
vinodkl
en respuesta a: Anonymous
Check this link on how get the that: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Data-e...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
