439 Vistas, 2 Respuestas
Exporting to EPS disconnects fillets
Hello All,
I am currently producing some vinyl decals for my car. I have drawn them out in AutoCAD and then exported them as an .EPS, so that the local signs and graphics place can cut them on their big plotter. However, when he imported the .EPS file into his software, all of the fillets and other rads had disconnected from the lines and had moved a few mm away. In the .DWG they are all showing as connected. As he can't open .DWG, I need to get the .EPS working correctly. Has anybody got any suggestions?
Cheers
vinodkl
en respuesta a: Anonymous
I have never worked with EPS, but try to join the lines in dwg to make polyline and then export it to EPS as said in this link:https://www.cadforum.cz/cadforum_en/qaID.asp?tip=1784
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
en respuesta a: vinodkl
That worked! Thank you!
