R_Tweed
en respuesta a: Anonymous
I think there is an issue with the bench top shape where it returns inward creating a conflict with your base shapes when lofted.  I think you would need to remove portions of the base in order to achieve the front and side views.
I'm not sure that this resolving your modeling issue with lofting rather than more of a practical construction of the shape.  The attached dwg shape was made using the base solids you had as a guide and then selective removing areas to blend with the top using the subtract boolean tool.
