- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Any .dwg file I have wants to open with AutoCAD Mechanical. If I try to change the file type association, the only apps it shows as available options are "AutoCAD Application" and it does not let me specify which application to use (MEP, Mechanical, AutoCAD, etc.). First question is how to I change it so any .dwg opens with AutoCAD? Second question, is there something that distinguishes an MEP or MECH file from an standard AutoCAD file and if so, can I tell it to open MEP files with MEP, MECH files with MECH, etc.?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
hi,
The Solution can be viewed here...
Still, I have Copied it below for reference.....not solved by me.....
I suggest to try from Control Panel\Programs\Default Programs\Set Associations . This settings page allows you to set the default program for every known filetype.
