07-28-2020
11:01 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-28-2020
11:01 AM
"You do not have access rights to \\" simply means your server or operating system is not allowing your OS login to use that folder. So...
Where are you saving your files to? Are you using a cloud file service?
What did your I.T. team suggest as a fix? They need to be involved.
Also post screenshots of the SAVEAS pop-up as well as the commandline results, lets see what you see.
What is your AutoCAD version as listed in ABOUT command?
What is your OS?
FYI there is an AutoCAD - Português forum over here if you want to use it https://forums.autodesk.com/t5/portugues/ct-p/156
What is your OS?
