ernstQ9LLC
en respuesta a: timothy_crouse
aperture variable changed from 3 to 10 to 20 to 50 neither of that worked.
i also think it is a mix between hardware or gpu problem with this video card and maybe this athena program configuration.
so i think i will have to live with the current way to change it via properties window instead of the common way :cara_de_decepción:
thank you anyways for you help :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
