2813 Vistas, 6 Respuestas
how to modify block's insertion point?
avoiding explode and remaking
Etiquetas (2)
imadHabash
en respuesta a: Anonymous
use Block editor , double click on your block or select it and type BE in command line . you can read here for more information >> Click <<
Imad Habash
en respuesta a: imadHabash
Thank you
Just for my own clarification, to be sure I understood
The insertion point within the block editor is 0,0,0 and not moving , “this is the sun”. I’m moving/updating the block position with all the attributes whether I need and not the insertion point itself.
and additionally need to use the BATTMAN command to update the attributes. yes?
imadHabash
check this lisp that will help you . >> Click <<
Note : Lisps not applicable for AutoCAD lt .
Imad Habash
can i use this lisp for different blocks in the drawing?
imadHabash
you can test it by your self .
Imad Habash
