vinodkl
en respuesta a: Anonymous
Looking at the two screenshot I could see the viewcube orientation being changed between two screenshots indicating you have the DYNAMIC UCS turned on. Learn more about DYNAMIC UCS from HELP
You can turn off Dynamic UCS using the F6 key or press ctrl+D and then try drawing circle:cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
