- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Multi-AnnoScale Block Attributes Move when Changing Scale
Hello -
I'm trying to create a best-of-both-worlds scenario with some annotative blocks, and I'm wondering if anyone has solved this issue.
In the attached file, there are two blocks. The block on the left is created such that there are grips for each attribute. The top grip moves the whole stack of attributes, and grips under that move individual attributes. When you switch annotative scales however, the text stays in place, which of course makes it look wrong in every other annoscale.
In the block on the right, the attributes are created such that the text is moved independently and stays in place when changing annoscales so it looks correct at different scales. The problem with this is there is no way to create a grip to move a stack of tags in this method, which is difficult when there is a large stack of attributes that need to move together.
Has anyone figured out a way to create grips that hold their position in different annoscales? If not, this seems like something Autodesk should add, as it is incredibly important for multiscale drawings.
Windows 10
Autocad 2020.1.3
