vinodkl
en respuesta a: ernstQ9LLC
Usually this happen when the PICKFIRST variable is set to 0. Type in the command "PICKFIRST" and set it to "1". Now try changing the layer from the layer dropdown:cara_con_una_leve_sonrisa: Hope it solves your problem.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
