ernstQ9LLC
1151 Vistas, 12 Respuestas
cycle through layers does not work anymore
the following error occurs: Normally i can select some lines and objects and then i select another layer in the drop down menu of layers. (it then changes the layer of my selected objects in real time + color changes + layer type etc.) but on this machine the layer drop down window just closes and the selected objects stay on the same layer like before  as soon as i hover over another layer. Same thing happens if i try that with hatches. So i have to change them via the properties window. Does anyone have a clue what could cause this Situation?
im using Auto cad 2020 64bit with Athena 2019 on Windows 10.
Etiquetas (1)
