Alfred.NESWADBA
en respuesta a: Anonymous
>> The template file DOES open when I issue QNEW on the command line.  But not in the other new file creation options.
That's the point: other new file creation options
Only the command _QNEW uses the template, but command _NEW does not. So if you use the old-style pull down menu "File" ==> "New" this does not start _QNEW, if you use the big-A menu ==> "New" does not start _QNEW, so none of them will open the template automatically.
With the default AutoCAD menu/default workspace only the 1st icon within the Quick-Access-Toolbar is starting the command _QNEW.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
