Alfred.NESWADBA
en respuesta a: Anonymous
sounds strange, my first try would be to copy the DWT file to a local folder and set within _OPTIONS the QNEW-setting to this file, does that work?
And as it sometime happens: are you sure you renamed the file correctly? When the Windows Explorer is set to hide known file-extensions a renaming might result in not-renamed extensions.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
