- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Sorry, but I think I am out of ideas....I have never had much luck with "pastespecial as ACAD entities" method, and the static image, whether embedded or x-ref'd, method a) doesn't update, and b) plots in rather poor quality. The method I outlined is the only one that has worked reliably for me (in my workflows) updating as needed, and being easily editable and/or replaceable when someone out there (sales, customers, etc) changes the game plan.
I will sometimes have multiple named ranges within a single xls file tied to several tables in a dwg, sometimes multiple xls files. If the excel files aren't where ACAD is looking for them, and the path(s) aren't available, the tables won't update. Fortunately, since I manage the files, I rarely encounter this issue. One thing to be aware of: you can only use a name once in a file. Each range, datalink, etc between each dwg/xls "pairing/grouping" has to have a unique name, otherwise things will get confused or simply not work.
Did you test @imadHabash 's suggestion(s)?
