06-26-2020
09:41 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-26-2020
09:41 AM
OPEN command inside AutoCAD will let you select individual or a select few (hold CTRL key down as you click on individual) or all DWG files in a folder (pick top file, then SHIFT key then select the bottom one): is that what you are looking for?
Or do you need to use Windows Explorer OPEN feature after you select the files you want in the same exact way as described above?
Or something else?
Or something else?
