06-19-2020
12:56 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-19-2020
12:56 PM
@imadHabash wrote:
.... check from LAYER command all of your layer plot status under Plot tab . it should NOT selected .
... if by "not selected" you mean not set for non-plotting. For each Layer that you want to appear in plotting, that symbol in the Plot column should not look like the upper one here [set to not plot], but rather like the lower one [set to plot ]:
If that's not the issue, @plyleraaron, I notice in your image that "None" is the setting under Plot style table (pen assignments). Is that what you want? Maybe -- you have Plot object lineweights and Plot with plot styles both checked, so could you have something in those settings for specific objects [rather than via their Layers] that would make them not show in plotting?
Kent Cooper, AIA
