plyleraaron
10896 Vistas, 3 Respuestas
Lines not showing when printing
I finished up a simple floor plan drawing, and I wanted to print it to have on paper, but in the preview window only a few lines are showing up.
This is what the preview should show:
But this is what the preview shows:
Here is the setup of the printing page:
Why would it be doing this an how do I fix it?
Etiquetas (2)
imadHabash
en respuesta a: plyleraaron
check from LAYER command all of your layer plot status under Plot tab . it should NOT selected .
Imad Habash
Kent1Cooper
en respuesta a: imadHabash
@imadHabash wrote:
.... check from LAYER command all of your layer plot status under Plot tab . it should NOT selected .
... if by "not selected" you mean not set for non-plotting.  For each Layer that you want to appear in plotting, that symbol in the Plot column should not  look like the upper one here [set to not  plot], but rather like the lower one [set to plot ]:
If that's not the issue, @plyleraaron, I notice in your image that "None" is the setting under Plot style table (pen assignments).  Is that what you want?  Maybe -- you have Plot object lineweights and Plot with plot styles both checked, so could you have something in those settings for specific objects [rather than via their Layers] that would make them not show in plotting?
Kent Cooper, AIA
plyleraaron
en respuesta a: Kent1Cooper
I never set the layers to not print but hey it worked. Thanks
