- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
One more tip
The Parts row in our template is a dynamic block. This may be a problem for 2015. The block DOES NOT have to be dynamic. I set it up that way for ease of access to the different row types.
Also, note the instructions in the CAD standard file illustrate how to set up the parts row inside a sheetset package.
The technique described allows you to paste row find linked bubbles throughout any of the sheetset drawing, pretty much ACAD Mechanical behavior.
There is an issue with this process in that when the PDF output is created ALL the part rows appear in the PDF navigation. This is helpful sometimes but if you do not want access to individual parts on the document navigation pane you would make a duplicate TAB and remove/delete ALL the named views and include that sheet in the publish set and disable the other sheet from publishing. The original sheet is still where all the part bubbles get linked to.
And that my friend is how we get ACAD Mech behavior inside Vanilla ACAD
Hope That Helps You On Your Way
Best Regards
Tim C.
