tkvesela
3637 Vistas, 3 Respuestas
Broken lines and poor quality pdf when plotting dwg to pdf
I have encountered a problem when plotting dwg to pdf. I am attaching a screenshot of the pdf (zoomed in), the drawing looks normal in my model space. I am using 2D wireframe and have tried ctb and stb, all the different plot styles and various plot settings (also various scales). I am using Autocad 2019.
I would be very grateful for any idea on how to fix this,
Tereza
Etiquetas (3)
j.palmeL29YX
en respuesta a: tkvesela
@tkvesela wrote:
... the drawing looks normal in my model space.
Do you plot the model space?
How looks your drawing in a (paper space) layout?
How looks the plot preview?
How looks a plot from the layout?
Did you try different plotters?
We don't know what exactly you do nor what you tried (what means "different plot styles" and "various settings"?).
Can you be more specific? And/or would you share your dwg file with us?
Jürgen Palme
timothy_crouse
What PDF setting are you using?
There is are multiple PDF qualities available in the list.
-Tim C.
tkvesela
en respuesta a: j.palmeL29YX
Thank you for your reply.
I managed to plot the pdf in acceptable quality by setting: AutoCad PDF
(high quality print).pc3 I have also changed the vector quality to 4800 dpi
and shaded viewport options quality to maximum.
