349 Vistas, 3 Respuestas
ASSOCIATIVE DIMENSIONS AND HATCH WITH PARAMETRIC FORM PROBLEM (AUTOCAD 2020)
Hy,
i have a file that i create with autocad 2013 with a parametric polyline. I associate dimensions and hatch with the polyline. With autocad 2013 i modify the polyline with dimension constrains and the hatch & normal dimension change with the polyline.
I open the same file in Autocad 2020 and it doesnt works. The normal dimensions & hatch result in the properties panel with associative but do not move with the polyline.
I try to create a new rectangular in autocad 2020 and i associate dimensions & hatch with it. If i modify the rectangular with a control point it modify dimensions and hatch. If i add a constraint dimension and i edit the number value, it modify the rectangle but the normal dimensions & the hatch dont move with the rectangle.
Any solutions?
