- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
You are using the wrong template (acad.dwt instead acadiso.dwt for example)
or without templates: Your setting is wrong (Measureinit=0 instead 1)
For New files, not based on a template, you have to set MEASUREINIT to 1
But..
You should use a TEMPLATE file.
Start a NEW file, set up all what you need every time (Textstyle, Dimstyle, Units..)
and save the file with file extension *.DWT
If you use NEW command, select this *.dwt
and/or
Set up your Quick New setting! for QNEW, so you don't have to select this file every time by hand.
Command: Options, Files, search the node for QNEW and add your new created *.dwt as default template.
BUT BUT
If you worked in the past this way:
New file (where MeasureMENT is set to 0) and then you only changed the UNITS setting/INSUNITS),
then you have a problem now, or later.
Depends on your Measurement setting, Acad uses the imperial or metric definition of linetypes and hatch pattern!
It is q big problem to merge them in one file..
From this point: Hope you get all information and help you need, i am out.
Sebastian
