vinodkl
en respuesta a: Anonymous
open a new drawing and then set the units in mm and then save as the drawing as template(.dwt)
now type in the command "QNEW" and then select this template. So that next time when you click on a new drawing it will be set to mm.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
