1309 Vistas, 8 Respuestas
why cant i set my units mm by default autocad student 2018
hi i would like to ask for help on regarding of units setting
when i open up autocad the units is always in inches when i try to do the setting i search up it doesnt help at all when i go on and open up a new file it will just go back to inches and i will have to we do the step to make it to mm before i draw
so i would like to ask is how can i have the units change mm when i open up autocad and dont need to use the command like ( units , dwgu ) those to change the page to mm
Etiquetas (1)
Etiquetas (1)
vinodkl
en respuesta a: Anonymous
open a new drawing and then set the units in mm and then save as the drawing as template(.dwt)
now type in the command "QNEW" and then select this template. So that next time when you click on a new drawing it will be set to mm.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
open from Ctrl+N a file template like ( acadiso.dwt ) . now it will always open as the last open . take a look here what are those templates can create ( Metric and Imperial ) . >> Click <<
Imad Habash
cadffm
You are using the wrong template (acad.dwt instead acadiso.dwt for example)
or without templates: Your setting is wrong (Measureinit=0 instead 1)
For New files, not based on a template, you have to set MEASUREINIT to 1
But..
You should use a TEMPLATE file.
Start a NEW file, set up all what you need every time (Textstyle, Dimstyle, Units..)
and save the file with file extension *.DWT
If you use NEW command, select this *.dwt
and/or
Set up your Quick New setting! for QNEW, so you don't have to select this file every time by hand.
Command: Options, Files, search the node for QNEW and add your new created *.dwt as default template.
BUT BUT
If you worked in the past this way:
New file (where MeasureMENT is set to 0) and then you only changed the UNITS setting/INSUNITS),
then you have a problem now, or later.
Depends on your Measurement setting, Acad uses the imperial or metric definition of linetypes and hatch pattern!
It is q big problem to merge them in one file..
From this point: Hope you get all information and help you need, i am out.
Sebastian
en respuesta a: cadffm
Hello. Is this solved or not yet ?
vinodkl
Hi, Do the replies solve your problem if you are facing the same issue:cara_con_una_leve_sonrisa:? If not, let us know how we can help you out.
cadffm
Sure.
Sebastian
RobDraw
en respuesta a: vinodkl
Units are a drawing setting. If you are opening drawings with units set to inches, that is most likely intentional. If you are starting a new drawing, you are using the wrong template.
Rob
cadffm
en respuesta a: RobDraw
based on a template file (dwt/dxf/dwg) you are using the wrong template.
If you start without a template, your MEASUREINIT setting is wrong.
Sebastian
