t.burns62
1785 Vistas, 6 Respuestas
Block text shifts
I opened up a drawing and all of the blocks that had text centered into it is now shifted to the right.  I have not changed any font style or the block.  It is puzzling to me.
pendean
en respuesta a: t.burns62
You have a missing font.
or your annotative blocks scale is affecting placement (or manually moved at one point).
Or... share that DWG file if you want more things to explore.
Thomas_Stuehle
en respuesta a: pendean
Hello Todd @t.burns62
Did the post by @pendean  helped you and answered your question?
If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
imadHabash
HI,
i suggest to try ATTSYNC command , if not fixed .. please attache a CAD dwg sample that represent your issue ?
Imad Habash
t.burns62
The font that is being used is not annotative. It is just Times New Roman  I was able to fix it on my computer but a friend of mine wasn't able to.  Last I knew they were going to uninstall AutoCAD and re-install it.
t.burns62
en respuesta a: imadHabash
I was able to fix it but doing a drawing utilities audit then I went to drawing utilities and did Update Block Icons and that fixed it.
Sagar_ShindeVW3PU
make the Z axis 0 for the text property and try
