381 Vistas, 2 Respuestas
Export file format for editing in Adobe suite
I need to translate the text of an instruction manual made with AutoCAD by a manufacturer. I need to make versions in other languages. I don't use and have AutoCAD. I would like to be able to have access to an editable file where I can search and replace strings of text. For example, in a app part of Adobe Suite for example Acrobat DC. What kind of file type I should ask for (file export in AutoCad)?
Thanks a lot in advance for your help.
dmfrazier
en respuesta a: Anonymous
You can ask for a PDF and then run the PDF through a PDF editor that has OCR.
pendean
Ask for a PDF with editable text.
