Neil.dixon
en respuesta a: Anonymous
Thanks, I tried audit and purge. Audit found no problems and I removed a few regapps, but I still have the same issue.  I tried turning off hardware acceleration as well, same issue. I think it might be a problem with the file because I get the same issue with the same file on a different computer, although nothing came up on audit. Not sure if there is a way of fixing the file. Thanks again for you help.
