vinodkl
en respuesta a: Anonymous
Use the command "QSELECT" to select the hatch and delete it based on the different properties of the hatch.
P.S if you have the hatch in a particular layer and you are not able to turn it on or thaw that layer then use the command "LAYDEL" and then select "NAME" from the commandline and specify the layer name to delete that layer. Note: make sure you don't have any other elements in that layer apart from the hatch.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
