06-02-2020
11:08 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-02-2020
11:08 AM
Hi @andreiamvale,
Thank you for posting, I am sorry to hear you are having a problem with the scale in your plotted drawings.
Thank you also for the files. I was able to run a few tests with plots using the settings in your drawings, they seem to be plotting and publishing to scale, but I could be missing something. Can you tell me where you are seeing the scale is not correct?
It would be help narrow down the cause if you could also post a ScreenCast showing steps to reproduce the issue and where the scale is incorrect.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
