vinodkl
en respuesta a: Anonymous
Sorry, your question seems to be confusing.
If I am not wrong are you talking about selecting the object first and then initiate a command is not working and you are required to select the object again. If that's the case type in the command "PICKFIRST" and set it to "1".
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
