pendean
en respuesta a: Anonymous
If you scale everything to match in size in modelspace, then nothing is at 1:1 scale, which will ruin your paperspace viewport scales if they are scaled and not just visually aligned.
Are you stating that actual 1:1 and plotted measurable scales are not needed in your file moving forward? Then just do it, there is nothing in AutoCAD to automated what you show in your screenshot in modelspace if I understood your responses so far.
EDIT: forgot to add, look up ALIGN command and its scaling feature.
HTH
