limlimlimmy
3062 Vistas, 3 Respuestas
Some lines are missing when exporting as pdf
Some lines are missing when I export it as pdf.  Checked other threads, can't figure out what's wrong with the drawing. I have attached the dwg file and the pdf.
pendean
en respuesta a: limlimlimmy
The missing lines have an RGB color 255,255,255, which is basically a no-color option, aka invisible: AutoCAD is doing what you ask, making them invisible in the PDF.
cadffm
White eagle on a white flagg.
Color7 is black!
Sebastian
Tiana_Y
Hi @limlimlimmy
Thanks for posting your question to our AutoCAD Community Forum! I'm just checking in to see if you need more help with this. Did the suggestions that @pendean and @cadffm provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
