ChicagoLooper
en respuesta a: Wojty1
Sorry, no. Isolate Selected Objects doesn't have any fade options. Isolate selected objects will result in HIDE so all objects that are not selected will be hidden and not faded.
The only option I can think of is to create an xref of your current drawing. Bring in the Xref and put it on a dedicated layer (a layer totally devoted to just the Xref). Turn the xref layer ON or OFF as needed.
When you perform isolate selected objects, be sure to turn ON the Xref, then select the Xref AND the objects you wish to isolate. Since Xrefs have a fade option, you can get the fade effect you want so badly.
Chicagolooper
