imadHabash
en respuesta a: Wojty1
>> If some of the administrators know how, you may contact me.
hope that @Tiana_Y  can help .
>> Is this AutoCAD's normal behavior?
Yes it's Normal , all the objects from the drawing will disappear leaving only drawing objects which you have selected. BUT if you want to make a Layer isolation with fade option , you can use LAYISO command with changing settings .
Command: LAYISO
Current setting: Hide layers, Viewports=Vpfreeze
Select objects on the layer(s) to be isolated or [Settings]: s
Enter setting for layers not isolated [Off/Lock and fade] <Off>:
Imad Habash
