2640 Vistas, 5 Respuestas
Copy with base point-Paste to original coordinates
Hello all,
I am working as a CAD drafter and I want to know that why sometimes "copy with base point and paste to original coordinates" does not work. Recently, I was working on one project and I wanted to copy one riser going up from level 1 floor plan to the exact same location on level 2 floor plan. I used copy with base point with 0,0,0 and when I paste it on 2nd floor, it went off the drawing. Interestingly, on another project this procedure was working fine. So, I would like to know what is the primary reason of this thing? What should I do or what settings should I apply first before starting on any project so that whenever I want to use  "copy with base point and paste to original coordinates", it will work. Currently, I am struggling with this and since I am not able to figure this issue, I have to measure dimensions off the grid lines before placing any equipment or riser and this is taking too much time. Please advise.
