193898
348 Vistas, 4 Respuestas
No linweight showing in my Layout
I am experiencing a problem namely does not show the lineweight in my layout. All the lines are the same thickness, even though I have the Lineweight turned on and it does show in the model tab where I made the design.
qnologi
en respuesta a: 193898
lwdisplay
qnologi
DavidDillonJr
@193898 Are you using CTB plotting or STB plotting?
If you are using CTB plotting try to use Monochrome.ctb when you print.
David Dillon
qnologi
imadHabash
Within page setup there is the setting "Display plot styles" which can override expected lineweights depending on the plot style file chosen.
Imad Habash
