coolkris
1817 Vistas, 7 Respuestas
3d rendering avoiding shadows in spot light and distance lights
Dear all,
Please find attached image, I want to avoid shadows of point light and distance light.
Krish
Alfred.NESWADBA
en respuesta a: coolkris
Which version of AutoCAD?
For newer AutoCAD versions you can't avoid shadows (I guess because of realism)
- alfred -
PS: no image attached
Alfred NESWADBA
(not an Autodesk consultant)
coolkris
thanks for reply still the shadow falls on image background from distance light i beleive. How we can avoid that.
Krish
Alfred.NESWADBA
What type of geometry is your background? If it's really just a background image and no geometry, no shadow should show up there.
Can you please run command _ETRANSMIT (to pack all together, drawing + images) and upload the file here ... that gives us the option to look into it. Please also let us know the version of AutoCAD you are using.
- alfred -
Alfred NESWADBA
coolkris
en respuesta a: Alfred.NESWADBA
good morning,
Please find attached etransmit and also rendered walkthrough. Shadow is "really" disturbing quality.
I use Autocad 2017.
Krish
Alfred.NESWADBA
you have seen these 2 dialogs?
Both are not good to have with your scene and especially the heavy number of lights you have.
Where does the dwg-file come from?
Have you set the lights or were they already defined when you started with AutoCAD and this file?
If you don't want to have a shadow for the background, then please don't use geometry for your background. Geometry objects receives shadows. Instead use the environment option to show a background as shown here:
- alfred -
Alfred NESWADBA
coolkris
thanks a lot, this was the output from tekla model, how to place the image exactly in the x,y,z co-ordinates. From the background option that will only stretch or tile etc.
Alfred.NESWADBA
placing a background like an image is not possible (not with AutoCAD afaik), but you can edit the image so it fits to the space/to fill the background :cara_guiñando_un_ojo:
- alfred -
Alfred NESWADBA
