05-18-2020
04:33 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-18-2020
04:33 PM
So the black rectangle with the white objects and white text is a block, correct? If this is correct, then check the layer hosting the block.
What is block's layer lineweight in the Layers Properties Manager? When the block is selected, what is displayed under the Lineweight section in the Properties Palette, By Layer? Or something else? For best results, the lineweight for the block should be controlled by the layer hosting the block, not controlled through the Properties Manager.
Chicagolooper
