05-12-2020
02:14 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-12-2020
02:14 AM
Hello @Anonymous
Welcome to the AutoCAD Forum.
Please check the following points:
- Does your computer meet the system requirements for AutoCAD 2015? Also note that version 2015 was never tested on a windows 10 environment in case you have a windows 10 environment on the mentioned machine. This might result in unexpected behavior of the AutoCAD 2015 version. It might be worth it to install a version of AutoCAD which was developed for windows 10.
- Check if your graphic card is listed under "Certified Graphics Hardware". Please select the product, the version and the operating system you are using. You will find a list of drivers which are recommended by the manufacturer of the graphic card. They tested these drivers for the listed circumstances and recommended them. If your graphic card is not listed, go with the most up to date driver from the website of the graphic card manufacturer. You find a video of how to use the webpage here.
Did the post by help you and answered your question? If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Thomas Stühle
