- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Your assumptions are right. The negative sign before the first 255 was just supposed to be a dash, they are all positive 255. You're right, changing my workspace didn't change the background, it only changed the colour of my white layers to appear black. It also caused my layer properties toolbox to appear above my main top ribbon, which is not where I usually keep it. I manually changed the background afterwards just to be sure. I tried both "dark" and "black". I did confirm that these layers that were appearing black were assigned to colour number 7 or number 255 (even the small box showing colour in the layer properties tab was appearing black even though when I checked it was assigned to white. I closed autucad altogether and restarted it, and it was still the same. I restarted my computer and I'm no longer experiencing this problem. If I can recreate this (I'm a little scared to try) I'll try to post so you can see. I appreciate the help, and if you have theories about why this happened I'd like to follow the logic. Thanks!
