stevenpalma
645 Vistas, 3 Respuestas
Table problems
When using tables to calculate square footages, you can put the subtotals as fields connected to a polyline.
You can then have them automatically total, thus removing the need to manually key in anything.
Well here is a rather annoying little problem, hopefully someone out here has run into this and has a workaround?
When inserting the value as a field from a polyline, if you choose to change the precision of the number displayed to a whole number it will automatically round that number either up or down based on the decimal amount. As one would assume if the amount is less than .5 it rounds DOWN and more than .5 it rounds UP.
Well here is the problem, you could have two numbers that are both less than .5 and so they would be rounded down, HOWEVER, the subtotal of those numbers could force he decimal portion OVER .5 thus rounding UP the subtotal.
When this happens it looks like this. Which it clearly looks like a math error.
But behind the scenes those numbers are actually this
Anyone ever run across this?
Help!
Etiquetas (1)
  • Tables
