- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Yes, the section is supposed to be perpendicular to the centerline. At first glance, it looks like you did it! Thank you very much for your help.
After you completed the array command, did you explode it and loft from section to section within the array? It seems like there would be a way to loft from section to section without manually clicking down the whole line of array items. I tried to recreate your steps and created an array with a small spacing between items and then started to loft between each section, just seemed really repetitive. Does it matter what the spacing is of the array prior to doing the loft command? I want to make sure I know exactly how you did this for future reference.
Also, do you have any ideas on how to create an arbitrary surface (or multiple) to represent the top of falsework? There will be falsework towers with header beams at locations along the curve with straight beams between them (provided by others). I am trying to determine the elevation they need to set their header beams/longitudinal beams to in order for us to build the ramp to the correct elevation.
