vinodkl
en respuesta a: AutoMarcus
The wipeout was not working in your drawing because it is in "DEFPOINT" layer:cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
Changing the layer fixed the problem.
And I personally don't prefer the table with no fill color when it overlaps on other objects, as the values will be hardly visible. You could change the fill color to 255,255,255 and the text color to 250 so that the text in the table will be visible and then objects behind the table will not be visible and in this way you could avoid the wipeout as well.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
